Using ag open on crawler dozer to pile brush
I have used ag open for field work and is a great program . I was woundering if any one has used in a dozer for piling brush ? And how to set it up . We usually push 150ft rows in long rows want gps to tell us when we at 150ft row line . Suggestions ?
Set your implement width at 150 ft
ok, but it not the same as driving tractor my width of cat is 22 ft but pushing to 150ft line from boundry
You could set the gap to 138 ft (or whatever). Or are you wanting autosteer for the pushing, and tell you when you get 150 ft in? Could generate tramlines for that I guess.
If you pin a flag at field edge as you start it should tell you how far you’ve driven from the flag. I used this feature this fall to help calibrate a drill in v5.5
