V4.5 Mounting position
Hello all. I am about to mount my AgOpenGPS box and want to make sure I mount it in the correct orientation. I see the BNO085 has an X and a Y with arrows. Does it matter which arrow is pointing in the direction of travel? Does the box need to be mounted flat or can it be mounted on its side or stood up on end as long as one of the arrows points in the direction of travel? TIA
You can set if you are using X or Y axis in AgOpenGPS. But the box must be mounted flat.
Can it be mounted on its side with the X arrow forward and the Y arrow up?
No, it must be mounted level with the tractor. It can not be stood on end.
