i want to test later this evevning and make some video.
Will this new version be compatible with the current v2 board? Or when adding new items will it be specific to a new one?
Have played a little bit with the simulatior and seems there is a problem with creating the headland.
When the creator tool is closed it is display quite wrong.
Somebody else saw this problem?
v4_upgrade will be compatible when released with PCB V2
9 posts were merged into an existing topic: CMPS14 Compass
Probably an issue - its in the middle of being worked on.
I am struggling to download and run the upgrade. I see the two files in the branches “master” and “V4 upgrades”. Which of these runs the new code or do I need both? Also the “V4 upgrade” has and ,exe file to start the program and the AGIO comes up but AOG does not. The “Master” file does not have a .exe file. What am I doing wrong so I can look at the new code. Also downloaded “Visual Studio” and can not run from there either, but I can see the code. Have never used visual studio before. In the older verisons V3.0 there was an .exe file to start the program.
Is there a good video on how to use “Visual Studio”? I am struggling trying to figure out how to use to be able to run the upgrade version.
Look earlier in this post where wwfarm replied to me. He posted the links to use visual studio to build v4. It is very simple, and only take a few minutes
Thank you for response. Do I need visual studio in order to get the source file to work? Does that create an .exe file?
Yes, it creates it and puts it in the folder. Watch the video, it’s very informative.
Edit
Be sure you include the .Net framework in visual studio
Its not an upgrade, its being worked on outside of github. At the moment there is nothing publicly to even try.
