(Variable) Rate control
Does your fertilizer spreader actually measure weight with a load roller?
We are using the rate controller for a fertilizer spreader but we input product density into the RC app. Based on a uniform product density the weight per acre can be calculated based on an actual volume per acre application rate. This is the way that most fertilizer spreaders work.
We have been successfully using this for fertilizer application this year.
