Does your fertilizer spreader actually measure weight with a load roller?
We are using the rate controller for a fertilizer spreader but we input product density into the RC app. Based on a uniform product density the weight per acre can be calculated based on an actual volume per acre application rate. This is the way that most fertilizer spreaders work.
We have been successfully using this for fertilizer application this year.
I have not attempted yet. Moving forward it would need to be imported into the latest slow poke version. It is where the code is heading and without usb.
First try adding P until it wants to oscillate. Back off the P until it does not oscillate.
If the performance is as necessary then you are finsished.
If you donāt have enough P and it is too slow to respond then try to add some D to keep it from oscillating as you increase P.
Only add I if it drifts slowly over time and you need to increase gain to get it back on track sooner.
P gain should be the highest. D gain should be less than 50% of P gain. Ideally less than 10% of P gain. I gain should be really small. Less than 5% of P gain. Probably less than 1%.
I donāt remember my final settings but it was P with a small amount of D. No I. There may be an issue with I if I recall correctly.
How is the rate calculated?
The fan speed sets the spreading width, gate opening and belt speed the product over time. Do you pick up the belt speed at some point to get a counts per unit value? Or can the rate controller figure this out with the entered density and no belt speed? That part Iām not clear of.
You have to determine the Counts per unit by calibration. Once calibrated and you know your Counts per unit no need to calibrate again unless something physically changes.
For a volumetric meter you would simply need to know the counts per rotation and if you know volume per rotation then you divide the volume by the counts and you have your counts per unit. Add in density and you can apply a weight per area rate.
Density is needed if your product density that is applied varies from batch to batch. With the fertilizer we apply each blend may be a different ratio of N, P and K so the density varies batch to batch.
If your density is constant then you can omit density and calibrate directly to pluses per weight or whatever unit instead of pulses per volume like me.
The combo close is because of the motorized valve that is used to control the belt speed. If you have a different control system you will need to switch accordingly.
Hey guys . Couple questions. First of all if planning on purchasing all new just starting off . It looks like a new teensy rate RC_11 is now available⦠? And with it what does it replace ? Is anything else needed along side it? Switch box? Anything else? Looks like relays are all on board⦠how many products and how many sections will it control?
Should also add here this project would just need 1 product , and not more than 8 sectionsā¦
And last of all how does it conect to AOG ?
Currently we have the new AIO V4.1 i think⦠micro board the latest steering board and tablet is direct connected to pcb with ethernet cable does this rate /section board connect in with a ethernet Y or a switch ?
Is there a product list item by item somewhere of all components needed to complete the board such as a teensy etc?
I really found the steering detailed wiki helpful it had a list of how to build boards , then additional parts to order then last of all the step by step programing for antennas , teensy, etc . Is there a spot like that for rate, / section control that lays it all out like that?
Sorry so many questions
if this type of setup questions isnt allowed on this forum is there specifically one around the rc11 board build and assemble specifically?
C.B. you will connect to the RC board via ethernet cable. You will need an ethernet switch to connect the AIO, PC and RC boards together. You might want to get a POE ethernet switch. You can find them on amazon that are powered by 12v. Then if you go to POE stuff later you can use it. I am using POE for section control on a planter.
I have not looked at the teensy board yet but I have found if teensy is available it is probably almost definitely better. I can show you my board but it is not a standard board it is for a dual rate application. No section control on board.
