I can’t get look ahead time setting on to go to 0 sec lowest it will go is .2 sec???
Pretty sure there is a bug in that version with section control timings.
Either try the latest v6.7 or an early version
ok thanks
I have downloaded 6.7 and deleted 6.6.2 but still can’t get look ahead to be less than .2 sec what am I doing wrong?
0.2s must be the lowest it can go then. The bug was in the turning on timings on v6.6.2
What are you wanting to do by wanting to go less than 0.2 seconds?
Turning on and off planter row units, I usually set coverage to 50% and it turns off at the touch of another row. I get a gap now on the start and shuts off at the touch of the row on the end
You manipulate the machine measurements to suit your on times then alter the timing for off instead.
Will give that a try thanks
