I tried to download the AgOpenGPS 6.3.0 source code and extracted the compressed folder. After opening AgOpenGPS.sln in Visual Studio 2022 and building the solution, I encountered these errors:
I even attempted extracting it with different software.
AgOpenGPS 6.2.0 works fine for me
I started experimenting with Visual Sudio and found I had those exact same errors.
Your missing libraries. They are not on your path.
I ve never used Visual Studio. I build everything from the command-line.
There something wrong in the structure i think. You said 6.2.0 works.
Is there not something to clean the project or rebuild. I can’t test it. I dont have Winforms.
It’s a fresh download. I’ve downloaded it like five times and used different extracting software, but nothing worked. I can load up 6.2.0 in Visual Studio 2022 tho.
I got it to work.
To fix red error codes I did a search of my hard drive found the files it wanted and copy and pasted them to folder it was looking in.
To fix yellow warnings I updated VS tools menu. get tools and features
then click .net deskop development.
and check windows app sdk C# templates
I also checked net framework 4.8.1 development tools
It looks like that is the ConfigOMatic application stuff. Seems like Brian is trying to package it with AOG but the files are not in the AOG repo.
