Has anyone else had issues with AgOpenGPS not fully launching from source code? It has happened several times right after successfully launching it the day before. Agio is fine and i see the icon for AOG in the taskbar but theres no window.
I just complied AOG and AgIO yesterday and it worked fine. The source is based on .NET4.6 and I accepted the prompt to update it to .NET4.8. Did you make any changes to the source?
No problems here with any version of AOG.
Have you used multiple monitors at any time? Delete the folder in %APPDATA% and see if that helps reset it.
That did it! Thank you!
