Additional info:
C/D-Can = J-1939
H/J-Can ISO-11783
A dull moment in this search engine
Gave some PGN’s And SPN off interest (searched for guide, angle and steer in the SPN Name field)
PGN’s that could be off interest
2304,8960,9216,43264,44032,44288,56832,61449,61451,61459,61469,61481,61757,64663,65032,65033,65144,65192
PGN PGN Description
SPN SPN Name
2304 See j1939_dl/ for details
5582 Static Roll Angle
5583 Static Roll Angle Status
8960 Tractor Implement Management (TIM) Server to TIM Client Status,
Operation and Function messages.
The first byte of the PGN contains the Message code or the TIM function ID.
8665 Auxiliary Valve 0 Flow
8666 Auxiliary Valve 1 Flow
8667 Auxiliary Valve 2 Flow
8668 Auxiliary Valve 3 Flow
8669 Auxiliary Valve 4 Flow
8670 Auxiliary Valve 5 Flow
8671 Auxiliary Valve 6 Flow
8672 Auxiliary Valve 7 Flow
8673 Auxiliary Valve 8 Flow
8674 Auxiliary Valve 9 Flow
8675 Auxiliary Valve 10 Flow
8676 Auxiliary Valve 11 Flow
8677 Auxiliary Valve 12 Flow
8678 Auxiliary Valve 13 Flow
8679 Auxiliary Valve 14 Flow
8680 Auxiliary Valve 15 Flow
8681 Auxiliary Valve 16 Flow
8682 Auxiliary Valve 17 Flow
8683 Auxiliary Valve 18 Flow
8684 Auxiliary Valve 19 Flow
8685 Auxiliary Valve 20 Flow
8686 Auxiliary Valve 21 Flow
8687 Auxiliary Valve 22 Flow
8688 Auxiliary Valve 23 Flow
8689 Auxiliary Valve 24 Flow
8690 Auxiliary Valve 25 Flow
8691 Auxiliary Valve 26 Flow
8692 Auxiliary Valve 27 Flow
8693 Auxiliary Valve 28 Flow
8694 Auxiliary Valve 29 Flow
8695 Auxiliary Valve 30 Flow
8696 Auxiliary Valve 31 Flow
8697 Auxiliary Valve 0 Automation Status
8698 Auxiliary Valve 1 Automation Status
8699 Auxiliary Valve 2 Automation Status
8700 Auxiliary Valve 3 Automation Status
8701 Auxiliary Valve 4 Automation Status
8702 Auxiliary Valve 5 Automation Status
8703 Auxiliary Valve 6 Automation Status
8704 Auxiliary Valve 7 Automation Status
8705 Auxiliary Valve 8 Automation Status
8706 Auxiliary Valve 9 Automation Status
8707 Auxiliary Valve 10 Automation Status
8708 Auxiliary Valve 11 Automation Status
8709 Auxiliary Valve 12 Automation Status
8710 Auxiliary Valve 13 Automation Status
8711 Auxiliary Valve 14 Automation Status
8712 Auxiliary Valve 15 Automation Status
8713 Auxiliary Valve 16 Automation Status
8714 Auxiliary Valve 17 Automation Status
8715 Auxiliary Valve 18 Automation Status
8716 Auxiliary Valve 19 Automation Status
8717 Auxiliary Valve 20 Automation Status
8718 Auxiliary Valve 21 Automation Status
8719 Auxiliary Valve 22 Automation Status
8720 Auxiliary Valve 23 Automation Status
8721 Auxiliary Valve 24 Automation Status
8722 Auxiliary Valve 25 Automation Status
8723 Auxiliary Valve 26 Automation Status
8724 Auxiliary Valve 27 Automation Status
8725 Auxiliary Valve 28 Automation Status
8726 Auxiliary Valve 29 Automation Status
8727 Auxiliary Valve 30 Automation Status
8728 Auxiliary Valve 31 Automation Status
8729 Auxiliary Valve 0 Exit/Reason Code
8730 Auxiliary Valve 1 Exit/Reason Code
8731 Auxiliary Valve 2 Exit/Reason Code
8732 Auxiliary Valve 3 Exit/Reason Code
8733 Auxiliary Valve 4 Exit/Reason Code
8734 Auxiliary Valve 5 Exit/Reason Code
8735 Auxiliary Valve 6 Exit/Reason Code
8736 Auxiliary Valve 7 Exit/Reason Code
8737 Auxiliary Valve 8 Exit/Reason Code
8738 Auxiliary Valve 9 Exit/Reason Code
8739 Auxiliary Valve 10 Exit/Reason Code
8740 Auxiliary Valve 11 Exit/Reason Code
8741 Auxiliary Valve 12 Exit/Reason Code
8742 Auxiliary Valve 13 Exit/Reason Code
8743 Auxiliary Valve 14 Exit/Reason Code
8744 Auxiliary Valve 15 Exit/Reason Code
8745 Auxiliary Valve 16 Exit/Reason Code
8746 Auxiliary Valve 17 Exit/Reason Code
8747 Auxiliary Valve 18 Exit/Reason Code
8748 Auxiliary Valve 19 Exit/Reason Code
8749 Auxiliary Valve 20 Exit/Reason Code
8750 Auxiliary Valve 21 Exit/Reason Code
8751 Auxiliary Valve 22 Exit/Reason Code
8752 Auxiliary Valve 23 Exit/Reason Code
8753 Auxiliary Valve 24 Exit/Reason Code
8754 Auxiliary Valve 25 Exit/Reason Code
8755 Auxiliary Valve 26 Exit/Reason Code
8756 Auxiliary Valve 27 Exit/Reason Code
8757 Auxiliary Valve 28 Exit/Reason Code
8758 Auxiliary Valve 29 Exit/Reason Code
8759 Auxiliary Valve 30 Exit/Reason Code
8760 Auxiliary Valve 31 Exit/Reason Code
8761 Front PTO Output Shaft Speed
8762 Rear PTO Output Shaft Speed
8763 Front PTO Automation Status
8764 Rear PTO Automation Status
8765 Front PTO Exit/Reason Code
8766 Rear PTO Exit/Reason Code
8767 Front Hitch Position
8768 Rear Hitch Position
8769 Front Hitch Automation Status
8770 Rear Hitch Automation Status
8771 Front Hitch Exit/Reason Code
8772 Rear Hitch Exit/Reason Code
8773 Machine Speed
8774 Machine Speed Automation Status
8775 Machine Speed Exit/Reason Code
8776 External Guidance Curvature
8777 External Guidance Automation Status
8778 External Guidance Exit/Reason Code
9216 Tractor Implement Management (TIM) Client to TIM Server Status,
8779 Auxiliary Valve 0 Flow Request
8780 Auxiliary Valve 1 Flow Request
8781 Auxiliary Valve 2 Flow Request
8782 Auxiliary Valve 3 Flow Request
8783 Auxiliary Valve 4 Flow Request
8784 Auxiliary Valve 5 Flow Request
8785 Auxiliary Valve 6 Flow Request
8786 Auxiliary Valve 7 Flow Request
8787 Auxiliary Valve 8 Flow Request
8788 Auxiliary Valve 9 Flow Request
8789 Auxiliary Valve 10 Flow Request
8790 Auxiliary Valve 11 Flow Request
8791 Auxiliary Valve 12 Flow Request
8792 Auxiliary Valve 13 Flow Request
8793 Auxiliary Valve 14 Flow Request
8794 Auxiliary Valve 15 Flow Request
8795 Auxiliary Valve 16 Flow Request
8796 Auxiliary Valve 17 Flow Request
8797 Auxiliary Valve 18 Flow Request
8798 Auxiliary Valve 19 Flow Request
8799 Auxiliary Valve 20 Flow Request
8800 Auxiliary Valve 21 Flow Request
8801 Auxiliary Valve 22 Flow Request
8802 Auxiliary Valve 23 Flow Request
8803 Auxiliary Valve 24 Flow Request
8804 Auxiliary Valve 25 Flow Request
8805 Auxiliary Valve 26 Flow Request
8806 Auxiliary Valve 27 Flow Request
8807 Auxiliary Valve 28 Flow Request
8808 Auxiliary Valve 29 Flow Request
8809 Auxiliary Valve 30 Flow Request
8810 Auxiliary Valve 31 Flow Request
8811 Front PTO Output Shaft Speed Request
8812 Rear PTO Output Shaft Speed Request
8813 Front Hitch Position Request
8814 Rear Hitch Position Request
8815 Machine Speed Request
8816 External Guidance Curvature Request
43264 See j1939_dl/ for details
3564 Lane Departure Warning Enable Command
9751 Lane Keeping Assist Enable Command
9752 Lane Centering Enable Command
8133 Current Region
8134 Current Sub-Region
9760 Requested Active Steering Driver Preference Mode
44032 Machine system feedback detailing status of machine relative to guidance operation
5238 Guidance estimated curvature
5243 Mechanical system lockout
5242 Guidance steering system readiness
5241 Guidance steering input position status
5240 Guidance request reset command status
5726 Guidance Limit Status
5725 Guidance system command exit/reason code
9726 Guidance system Remote Engage Switch Status
44288 Steering command expressed as desired curvature
5237 Guidance curvature command
5239 Guidance curvature command status
56832 See j1939_dl/ for details
988 Trip Group 1
989 Trip Group 2 - Proprietary
1584 Service Component Identification
1211 Engine Build Hours Reset
3600 Steering Straight Ahead Position Reset
6218 Engine Spark Plug Secondary Voltage Tracking Reset
6219 Engine Ignition Control Maintenance Hours Reset
6898 Bin Lift Count Reset
6985 Tire Configuration Information
6986 Tire Sensor Information
61444 See j1939_dl/ for details
899 Engine Torque Mode
4154 Actual Engine - Percent Torque (Fractional)
512 Driver's Demand Engine - Percent Torque
513 Actual Engine - Percent Torque
190 Engine Speed
1483 Source Address of Controlling Device for Engine Control
1675 Engine Starter Mode
2432 Engine Demand – Percent Torque
61449 See j1939_dl/ for details
1807 Steering Wheel Angle
1811 Steering Wheel Turn Counter
1812 Steering Wheel Angle Sensor Type
1808 Yaw Rate
1809 Lateral Acceleration
1810 Longitudinal Acceleration
61451 See j1939_dl/ for details
2927 Actual Inner wheel steering angle
2928 Axle Location
2923 Status of Steering Axle
2922 Steerable Lift Axle Lowering Inhibit
2924 Steering Type
2925 Type of Steering Forces
2926 Type of Steering Transmission
61459 See j1939_dl/ for details
3318 Pitch Angle
3319 Roll Angle
3322 Pitch Rate
3323 Pitch Angle Figure of Merit
3324 Roll Angle Figure of Merit
3325 Pitch Rate Figure of Merit
3326 Pitch and Roll Compensated
3327 Roll and Pitch Measurement Latency
61469 See j1939_dl/ for details
3683 Steering Wheel Angle
3684 Steering Wheel Angle Range Counter
3685 Steering Wheel Angle Range Counter Type
3686 Steering Wheel Angle Range
3687 Steering Angle Sensor Active Mode
3688 Steering Angle Sensor Calibrated
3689 Message Counter
3690 Message Checksum
61481 See j1939_dl/ for details
4976 Pitch Angle (Extended Range)
4977 Roll Angle (Extended Range)
4978 Pitch Angle Compensation (Extended Range)
4979 Pitch Angle Figure of Merit (Extended Range)
4980 Roll Angle Compensation (Extended Range)
4981 Roll Angle Figure of Merit (Extended Range)
4982 Roll and Pitch Measurement Latency (Extended Range)
61757 See j1939_dl/ for details
9753 Lane Keeping Assist Status Right Side
9754 Lane Keeping Assist Status Left Side
9755 Lane Keeping Assist Indication Enable Status
9756 Lane Keeping Assist System State
9757 Active Steering Driver Preference
12855 Hands Off Detection Status
12854 Hands Off Detection Availability
9758 Lane Centering Indication Enable State
9759 Lane Centering System Status
64663 See j1939_dl/ for details
6375 Requested Steering Mode
6376 Front Steering Axle Centered Status
6377 Rear Steering Axle Centered Status
6378 2 Wheel Steer Actuator State
6379 4 Wheel Steer Actuator State
6380 Circle Steer Mode Actuator State
6381 Crab Steer Mode Actuator State
6374 Steering Controller ECU Temperature
11733 Steering Mode Two Wheel Switch Input
11734 Steering Mode Crab Switch Input
11735 Steering Mode Circle Switch Input
11736 Steering Mode Status
65032 Implement CF or task controller request to the Tractor ECU for
a desired tractor classification and tractor facilities
5233 Speed information - engine speed
5233 Speed information - ground based speed
5233 Speed information - wheel based speed
5233 Power management - maintain power
5233 Power management - maximum time tractor power
5233 Power management - key switch
5232 Tractor ECU class request
5233 Language command storage in Tractor ECU
5233 Lighting - minimal set as existing trailer connector
5233 PTO information - rear shaft engagement
5233 PTO information - rear shaft speed
5233 Hitch information - rear in work
5233 Hitch information - rear position
5233 Estimated or measured auxiliary valve status
5233 Lighting - full implement lighting message set
5233 Additional hitch parameters - rear draft
5233 Speed and distance - wheel-based direction
5233 Speed and distance - wheel-based distance
5233 Speed and distance - ground-based direction
5233 Speed and distance - ground-based distance
5233 Time date
5233 PTO commands - rear PTO mode/gear command
7445 Limit/request status reporting
5233 Auxiliary valve commands
5233 PTO commands - rear PTO engagement command
5233 PTO commands - rear PTO speed command
5233 Hitch commands - rear hitch position
5233 Direction control
5233 Machine selected speed control
5233 Operator external light controls
5233 Navigational pseudo-range noise statistics
5233 Navigational system position data
5233 Navigational system high-output position
5233 PTO commands - front PTO engagement command
5233 PTO commands - front PTO speed command
5233 Hitch commands - front hitch position
5233 Additional hitch parameters - front draft
5233 PTO information - front shaft engagement
5233 PTO information - front shaft speed
5233 Hitch information - front in work
5233 Hitch information - front position
5233 Drive Strategy Status and Commands
5233 External Guidance Status and Commands
5233 PTO commands - front PTO mode/gear command
5236 Tractor facility reserved bit indicator
65033 Tractor response to an implement CF or a task controller request for
tractor classification and facilities
5235 Speed information - engine speed
5235 Speed information - ground based speed
5235 Speed information - wheel based speed
5235 Power management - maintain power
5235 Power management - maximum time tractor power
5235 Power management - key switch
5234 Tractor ECU class response
5235 Language command storage in Tractor ECU
5235 Lighting - minimal set as existing trailer connector
5235 PTO information - rear shaft engagement
5235 PTO information - rear shaft speed
5235 Hitch information - rear in work
5235 Hitch information - rear position
5235 Estimated or measured auxiliary valve status
5235 Lighting - full implement lighting message set
5235 Additional hitch parameters - rear draft
5235 Speed and distance - wheel-based direction
5235 Speed and distance - wheel-based distance
5235 Speed and distance - ground-based direction
5235 Speed and distance - ground-based distance
5235 Time date
5235 PTO commands - rear PTO mode/gear command
7444 Tractor Facility Response - Limit/Request Status Reporting
5235 Auxiliary valve commands
5235 PTO commands - rear PTO engagement command
5235 PTO commands - rear PTO speed command
5235 Hitch commands - rear hitch position
5235 Direction control
5235 Machine selected speed control
5235 Operator external light controls
5235 Navigational pseudo-range noise statistics
5235 Navigational system position data
5235 Navigational system high-output position
5235 PTO commands - front PTO engagement command
5235 PTO commands - front PTO speed command
5235 Hitch commands - front hitch position
5235 Additional hitch parameters - front draft
5235 PTO information - front shaft engagement
5235 PTO information - front shaft speed
5235 Hitch information - front in work
5235 Hitch information - front position
5235 Drive Strategy Status and Commands
5235 External Guidance Status and Commands
5235 PTO commands - front PTO mode/gear command
65144 See j1939_dl/ for details
39 Tire Pressure Check Interval
466 Steer Channel Mode
1467 Trailer/tag Channel Mode
1468 Drive Channel Mode
1469 PCU Drive Solenoid Status
1470 PCU Steer Solenoid Status
1471 Tire Pressure Supply Switch Status
1472 PCU Deflate Solenoid Status
1473 PCU Control Solenoid Status
1474 PCU Supply Solenoid Status
1475 PCU Trailer, Tag or Push Solenoid Status
65192 See j1939_dl/ for details
1120 Articulation Angle
9652 Articulation Angular Velocity
