Wheel angle sensor unable to zero, this has happened twice now. First time it started working all of a sudden. I swapped out sensor with new one and no change. Any ideas?
Try turning up your counts per degree
No change in value of sensor angle when values are changed and when wires are unplugged.
Look like full left, so no WAS connected! Check all connections to WAS, does it have 5v from PCB?
Yes 5v and continuity tested the 3 wires. All checks out normal.
I reinstalled AOG to computer and is working correctly again.
