This WAS is said to be “Infinitely short-circuit proof”
Does this mean polarity is not important, or is it just not working if polarity is wrong?
It’s not working, but you can’t damage it.
I’m using 424A06A120:
1… 0V
2… UB 5V
3… Out 0.5-4.5V
Yea… Swapped the polarity and was able to measure different voltage when turning the sensor.
But AOG does not react on it.
It did with my other WAS
Any software settings I have forgotten?
What is the exact model of the sensor? Some models work with 10-30 volts, for example my model is 424A17A120B and I use it with 12 volts, but the output voltage is 0.5v-4.5v
I got it working. Don’t know exactly what it was, but it worked after enabling the simulator.
I also use tractor. It is a very high quality sensor.
Good to know. It seems decent.
I cross a river a few times during the year, and the sensor will get wet drowned now and then.
I bet there’s a bad wire connection before the sensor gives up.
