I am making a base station using the ardusimole simplertk2b and the wifi ntrip master. My question is, when configuring the ntrip master to send correction to rtk2go.com which of the three ntrip options needs to be filled out with the mount name, password, etc? Thanks for any help!
NTRIP terminology is so confusing.
I believe the section “caster” is about turning on a local caster on your wifi. If you want to connect to RTK2Go I think you turn on the NTRIP Server section and fill in the caster’s IP address, the mount point, and the password (which rtk2go now requires for casting).
Ntrip server as said^
