I’m seeking guidance for integrating a feather switch with my planter’s control system using the AgOpenGPS platform. My planter has two sections, and I need the system to detect when the planter is raised (out of the ground) or lowered (in the ground).
- Feather Switch Integration:
- I have installed a feather switch on my planter to detect its position.
- I’m uncertain about the correct wiring process, specifically which Pin on the Ampseal connector should the feather switch be wired to for accurate detection?
- Board Configuration for Two-Section Control:
- I’m currently using the 4.1 board, which I understand has one section labeled.
- Is it possible to configure this board for controlling two sections?
- If so, how can I set this up without needing a separate Arduino for two-section control?
Thank you in advance for your time and assistance!
