Wont connect to caster
Have been using my AIO V2.4 standard with AOG V6 i think, and it just decided after 20 feet today after starting to not connect to caster… no settings changed… not sure what to check
Should also mention that i am using rtk2go and my own base station. Mount point is COALDALEAB and the data is good
Well that one sorted itself out. Maybe a problem with rtk2go.
Sounds like an rtk2go problem. That used to happen all the time for me until I switched to rtkdata.online
I assume that the base station outputs directly to rtkdata? Im sure that its posted here somewhere, could someone share the post on how to publish the mount to rtkdata?
Pretty straight forward.
Go to rtkdata.online and create an account.
Then it should be easy to follow the steps to create your mount.
Then enter the data in rtkbase.
