thinking while sowing on the weekend, going back n fore on a decent 500m run
would it be possible to tap on the screen on the last coloured in run and see the info like length and area?
i know you can see field worked info ,but as i was getting low on seed i was thinking if i could see the last run info and the area you would have a pretty good idea if you could make it back up and down the field again ![]()
I want something similar to this too. I spread quite a bit of chicken manure, and use aog more as an application record rather than guidance. For every load I do I change the colour of the applied area, but I would like to be able to see the area applied for each colour / load. Thought it might also be a useful feature for combine / forager drivers to be able to record individual tank loads / trailer loads for basic yield monitoring
I also think something similar would be useful as well. Even a couple independent reset able acre counters would be really nice. My planter monitor has three such acre counters. I use one each for fertilizer, seed, and insecticide and reset each one when I refill itβs product. It also allows you to pause each counter independently.
It would be great too if there was a way to output that worked area into the SMS software for tracking purposes! I manual enter my dates and rates today, but if i could upload the worked area GPS map that would be awesome, because then i could overlay harvest info with plant or spray info.
Iβm not all that familiar with SMS anymore, but surely you can export the isoxml from agopengps and import it into SMS?
