Here is the KML writer for the Recorded path.
In the SaveOpen.Designer.cs about line 1815 just before //flags ******** insert all of this:
//Recorded Path
kml.WriteStartElement("Folder");
kml.WriteElementString("name", "Recorded Path");
kml.WriteElementString("visibility", "1");
//for (int i = 0; i < recPath.recList.Count; i++)
linePts = "";
kml.WriteStartElement("Placemark");
kml.WriteElementString("name", "Path " + 1);
kml.WriteStartElement("Style");
kml.WriteStartElement("LineStyle");
kml.WriteElementString("color", "ff6509ff");
kml.WriteElementString("width", "2");
kml.WriteEndElement(); // <LineStyle>
kml.WriteEndElement(); //Style
kml.WriteStartElement("LineString");
kml.WriteElementString("tessellate", "1");
kml.WriteStartElement("coordinates");
for (int j = 0; j < recPath.recList.Count; j++)
linePts += pn.GetLocalToWSG84_KML(recPath.recList[j].easting, recPath.recList[j].northing);
kml.WriteRaw(linePts);
kml.WriteEndElement(); // <coordinates>
kml.WriteEndElement(); // <LineString>
kml.WriteEndElement(); // <Placemark>
kml.WriteEndElement(); // <Folder>
That should do it. The red wiggly line is what I recorded and saved.
And using my graphics to curve importer, this is it running with the left edge on the recorded path line, via a curve picked from the KML file of the recorded path. Doing the U-turn, it looses the path in that tight corner. Because it jumps from one curve to the next one when it can’t make the turn.
