Looks like you would not send RTCM 1005 at all?
actually i couldn’t activate it in any way. it doesn’t activate even if i want to activate it
I cannot remember how it goes but could it be from missing base station coordinates?
ı try it but ı didint.
I click set in ram but I’m not sure it’s set. ı must set all of them?
I am very new to this subject. and I know very little about the subject
Yes, set to all 3 then send config changes. Do for each uart and usb. You will see the setting on the message change to the value.
after you are done go back to old config view, in CFG highlight 4 devices and send. That’s all
thank you everyone my problem solved ![]()
It might be helpful for others if you tell me what is causing the problem.
yes of course you are right. I could not activate the “rtcm3 1005” data packets sent by the base station. What I needed was to do this.
""Need to make sure the BASE is in TIME mode, ie has a fixed/static location.
Need to set via UBX-CFG-TMODE3, or have it complete a SURVEY-IN operation.
Enable UBX-NAV-PVT and UBX-NAV-SVIN so you can see that it’s in TIME mode, and that the survey is working/in-progress
When you look carefully, the fix mode has changed, now time and DGNS
