I have an old 60 ft Ag Shield sprayer that has only 2 controllable sections. I’m using the PCB V2. I don’t know if auto section control is worth doing, but I’d like to add a second work switch input so that both sections switch on/off in AgOpenGPS. Is there any way to do that? I might just build a simple section control board if it’s easier, but I’m not sure how to integrate that with my Raven 440 rate controller. It might be worth switching over to the AgRate Controller.
You can use this section control, GitHub - Xilofeon/Section-Control-for-AgOpenGPS
its simple and easy to setup. Then just use the input pins, then you can add output later,
Thanks. I’ll try that.
Gnd to pin A5 is section 1, and A4 is section 2, you need the switch gnd to D11 to activate, thats all you need if you connect over usb
