Good day, I’m new to AOG so I’m not sure what I’m missing here. The ADS1115’s That I get in the mail don’t resemble the rest of yours. It seems like they have been updated. But now I see the new All in One PCB is designed for what I thought was the old ADS1115. I’ve ordered directly from Adafruit, and I got the unit that is pictured on their site. I then saw the difference and ordered one from Digikey as theirs was pictured like the “old one”. Well I ended up getting this “new version” that Adafruit had originally sent me. Any suggestions?
I’ve attached the links to the units that I ordered.
The new one should work fine. Looks to me like you could put the pin headers on the side of the breakout board that has vin, gnd, scl, sda, and alert and solder that to the all-in-one board using the left-most 5 pin holes. Then use wires to go from the A0,A1, A2, and A3 holes on the other side of the breakout to equivalent holes on the all-in-one board. You’d likely want to support the board with some hot glue or something since the mount holes and standoffs wouldn’t work.
I’d bring it up with Digikey, ask them what’s up with the incorrect picture. You won’t need an extra ADS for the new dual PCB if you get one with the onboard surface mounted ADS unless you damage it somehow, then an external ADS board is suppose to work as a replacement.
Sounds good, I think I’ll try and return these for I plan on using the new All in One. And Thank you for the jumper suggestion, I’ll try that on a board I have here already.
