Hello everybody.
With the help of tony we managed to steer the new fendt one models via agopengps via can bus.
The software activation “steering for third-party providers” must be activated on the tractor. This makes it possible to send the steering commands to the steering valves via the V-bus.
The original fend button on the joystick is evaluated via the k-bus. If the button is pressed, the automatic steering switches on. If you press it again, it switches off again. If you reach into the steering wheel, the steering is also switched off. You can find videos and photos on the dropbox link. Installed and tested on a fendt 211 vario one 2022.
Moderator edit: Dropbox link is dead
many thanks to tony and the whole agopengps development team.
Hey, could you please describe what you found out? I’m planning to equip my 314 Fendt One with agopen over canbus, because it worked very well on my case tractor. Fendt tractor came with 3rd party steering unlock.
Engage/disengage with armrest buttons would be nice, but not necessary. On the case it automatically disengages when i grab the steering wheel and automatically reengages when the steering wheel isn’t moved for a second which is pretty nice tho. Hope this also works on the fendt.
When i get my hands on another Fendt ONE , i’m sure i can make the Go and End buttons work. I’m still stuck with the active stop (pushing the F/R flipper forwards while driving) I found the Can bus code that is beeing send when i push the flipper forward, but i can’t reproduce it. The tractor wont stop.
