Here my config to use u-Blox NEO-M8T with Agopengps note now I use a cheap antena and is difficult to get “Fixed”. With better antena and better signal to noise ratio I hope to get a better solucion.
as a new user I can not upload images and add links* can some one help with this?
Hardware components:
u-Blox NEO-M8T
usb-ttl
Software components:
u-center (only for initial M8T config) hxxps://www.u-blox.com/en/product/u-center
In Catatalonia we have the Institut Cartogràfic i Geològic de Catalunya that provides free ntrip corrections for Catalonia region. (hxxp://catnet-ip.icgc.cat you can register for free)
Also for other Spanish regions the Instituto Geografico Nacional provides free corrections hxxp://www.ign.es/web/ign/portal/gds-gnss-tiempo-real
First, with u-center we need to configure the module. To connect the module to computer with USB port you need a USB to TTL adaptor (I recommend with the chip CP2102 or CP2104)
select de baudrate to 115200 and Protocol out UBX+NMEA:
The rate shoud be ok 1 per second (the correction rate from catnet-ip.icgc.cat is 1hz) more rate can saturate the gps module! (5 can be ok but better as low as possible if it works fine.)
(upload://2r5QOoeXTLle6v2SJ1QcudxQUoX.png)
If you are in Europe select only gps,sbas,galileo and glonass
(upload://uKte2BrZ5Ie2kmHbfXTtag8uLTA.png)
Enable UBX messages for UART and USB 02-13 and 02-15
(upload://nYjuE83cAdxC3aTjG59JjJEq7id.png)
upload://38kiADfq2MzFjpccX8DQIUNTtLJ.png)
Remember to save the settings to flash, if not on powerloss the settings are cleared!
(upload://p0UGAuDUkKxmqT5MgERtej03rrF.png)
Once the module is configured we need to create a virtual pair serial COM ports. This is to transfer the corrected NMEA from rtklib to Agopengps (once installed, simply click on “AddPair” and remember the port numbers! i my example com1 and com 2)
(upload://70IMM749zttjwPCEVqJSVNug9zM.png)
Now is time to get the RAW UBX satellite observation from neo-m8t to RTKNAVI64 and apply the ntrip correction and output a NMEA to COM1
(upload://iGoLFZG51hL2wJoLZPuB9w01FMP.png)
Serial Options COMport where is the M8T module and speed 115200, format u-Blox
Mount point must be someting like VRS3 and the Format must be RTCM3
(upload://W5MWNunlf5D5LgDwz7QU5tkQRG.png)
Output Stream is the corrected NMEA to transfer to Agopengps, to do so, we configure the Virtual COM port we created before (my case COM1 and speed 115200)
(upload://79Pyp4Z8Yoqqw4R0O8HF3fhCmCG.png)
Other options
upload://tYHNM8F6dPwHSjPv0NCgRhemyRG.png) (upload://v2f6fnuNmoRzogPij4BWwoetChX.png)
And finally configure AgopenGPS to use the corrected NMEA from COM2
(upload://797AGrfmdCnrHQqBJbOrSIwunGq.png)
Final Note; with the module u-blox ZED-F9P all of this is not necessary but the price is 200 euros VS 50 euro
In Catatalonia we have the Institut Cartogràfic i Geològic de Catalunya that provides free ntrip corrections for Catalonia region. (http://catnet-ip.icgc.cat you can register for free)
Also for other Spanish regions the Instituto Geografico Nacional provides free corrections Instituto Geográfico Nacional
Other options
Just had another quick read…
Solution Format
Set the output solution format. ‐ Lat/Lon/Height : Latitude, longitude and height ‐ X/Y/Z‐ECEF : X/Y/Z components of ECEF coordinates ‐ E/N/U‐Baseline: E/N/U components of baseline vector ‐ NMEA0183 : NMEA GPRMC, GPGGA, GPGSA, GLGSA, GAGSA, GPGSV, GLGSV and GAGSV
outsolformat
For RTKNAVI, specify options as Output Streams setting.
…… I don’t actually see VTG, although it should be part of NMEA0183 ?
@Brofarm, I haven’t tested my setup on field, because the GPS antenna is the free one I got with the module. (small square antenna with IPEX connector)
On RTKNAVI to get a FIX position the signal to noise ratio of 6 satellite must be around 50, if you see my screenshot is about 30-40 and most of the time I’m Floating.
I selected 1Hz because the NTRIP provider, provides one correction per second, I would like to test with that value, but provably I’ll have to increase at least 5Hz (I don’t know the limit for M8T)
However, the direction of travel can be obtained from AOG’s [GPS Heading From] -[Fix to Fix Calc].
Until last year I used two pairs of M8P and TW2710 Antenna. In open sky, within 5km, more than 90% fix was obtained.
(use GPS,BDS,QZSS .(base)UBXraw:ntrips -(rover)UBXraw:serial.5Hz)
After some test with the neo-M8T I arrived to the conclusion that is not a good module to use as a single device for acuracy.
The module price is about 60 euro, is a single frequency and you need a good antenna to get stable FIX position. In total you need to spend +200euro for this solution.
With the module zed-f9p is a bit more expensive, but because is dual frequency, with a 100 euro antenna and NTRIP internet correction you get a better solution. And the total price is less than 300euro. For less than this I think is difficult to get an stable accuracy.
I’m not familiar with M8T at all but I assume it would work reasonably well if the distance to base was not too large. Minolu-JP seems to confirm this. Using a pair of M8T receivers could be a low cost option, one as a base, the other one as a rover?
Note that the 1 Hz RTK correction data rate does not limit the receiver to 1 Hz measurement rate. 1 Hz is too low from most Ag applications but you can go as high as the receiver allows while still keeping 1 Hz correction data rate (I assume you cannot even change that from a public source).
Why would one want to have SBAS included when aiming for RTK? For fall back? I’d disable SBAS if that allows faster RTK position measurements.
Anyway, very useful instructions. Interesting also for us who are not using the M8T receiver.
Hi @jpm I am interested of your com0com-setups, because mine seems to be working. I made one COM port pair COM (10) - COM (13). The solution sends the data to COM (10) and AutoSteerboard reads that data from port COM (13).
With rtknavi, a base station about 30km away (via rtk2go.com), 5hz refresh, the cheap antenna it came, and DIY “grounding plate” (old CD side down, not sure if it’s actually helping!) I am getting decent results (well, better than expected and good enough for my projects). It’s usually in float but in my naive tests (moving it around in measured patterns) it’s <5cm accuracy (at least relatively) and stable. There is drift near buildings though.
Note- after I unzipped and ran rtknavi I think the position for the base (in options) was set (to a wrong value)- should take position from NTRIP stream.
first of all sory my englis is bad… i have some trubles whit seting up the neo m8t … im not shure why… so i make all the steps like up in the pictures but whit the bauthreate 115200 wont work its looks like the 9600 works only? it looks like i do have some conections and signal wit rtklib but no corection steream the closest rtk base is 100 km away i konw its farr but i just wann try make the rower work first. if it works so i can order hardware fore base station… so any advice wold be helpful tnx
