Hello how are you ? Could you provide the specs for the wheel angle sensor or some links where I can buy it? eg 2 . As a hand, the car brand is also available :). Thanks everyone.
Many examples here.
Look both at bottom and top ![]()
I use the Land Rover sensor because it was available and comes with a nice pivot arm attached. Just search Land Rover in this forum for all the details and pin config.
I use rqh100030 Land rover sensor.
They don’t come with connector so you must order separately.
Range is ±35deg
Thank you for your help ![]()
Do I need to make any changes to the software for the RQH100030?
No software changes for any 1-5V sensor, just setup from the menus in the guidance program. Setting from menu direction, counts per degree, was zero, and ackermann.
How do you connect that sensor, doesn’t Agopen only need 3 pins and there is 6 pins on that sensor?
Yes there are six pins but i only use three, I think they are redundant.
Which 3 pin picture is it possible to mark with?
I bought my from autodoc. Mercedes RQH100030 - 0105427717 , it has shorter arm
The length of the connecting arm must be adjusted very carefully, because the plastic arm of the sensor breaks very easily!
https://photos.app.goo.gl/Ft5wtPKtTmfBqs7D9
I really liked this group. thank you iulian
First of all, welcome to our AOG community, I learned a lot here.
“If I give you an apple, if you give me an apple, I will have an apple and you will have an apple. If I give you one piece of information, if you give me one piece of information, I will have two pieces of information and you will have two pieces of information.” Confucius
Whiterose, awesome thank you so much
