Previous post had a few replies but figured I would revive the chat. Has anyone rigged up a standard scale to provide lbs/acre readout?
Going to be putting a amazon scale kit on our drill this spring and would love to connect it into AOG to get rate read out.
I’m just getting started with Agopengps and I just thought of an additional use for the tablet in the tractor is being a Bluetooth scale head as some seeding implements, fertilizer applicators and grain carts have loadcells on them. It would be nice to be able to get everything into one display.
Cur
DLT00
13 May 2026 00:13
2
Curious how your project is working? Im needing a scale system on my grain drill but Scale tec quoted me around $4500 usd for just one box and i have 3 boxes on my drill.
Replacing the electronic box is fairly easy if you only need the weight, no fancy options.
HX711 would be the module to plug on a nano or similar.
I have load cells form AliExpress, they work but I don’t know for how many years, that said, the agricultural ones also fail.
I have a planter controller code on my GitHub, with load monitor. I will post here when working.
I went with a livestock scale from loadcelldepot.com . $500
Just got it installed, copied the bracketa from scaletech and others.
