You will want to use the ino in the 4.1 firmware folder
Is there anything I need to change in the 1.13 configuration? Under system settings raw Hz is showing around 2hz and Hz is showing 8hz. This doesn’t seem right and it is not working well. Uart 1 and 2 on both receivers are set to 460800.
