I stupidly ordered my standard f9p’s without headers as I thought I would only want a lightbar, but I now want to try autosteer. What size headers do I need to solder on the ardusimple f9p to allow it to fit on v4.5 standard board?
0.1” or 2.54mm. They are usually available in 40 pin lengths and then you can cut off as many pins as you require.
I don’t know off the top of my head what height the pins are, they are whatever the most common type is. If you find 0.1” headers online for Arduino projects, they’ll be right.
