As @TERVUREN said.
In addition to this you can take a look at dcmotorkeya.com.
Yes, it is more expensiv but I think it looks better ![]()
As @TERVUREN said.
Looks interesting, please can you introduce your steering setup and post more information.
How do you handle RS232?
Did you made the adapter for steering wheel by yourself?
What is your experience with your motor, is the smaller one rated torque of 7N also enought?
@wland
I am using an ESP32 with a modified code from Matthiasâ Autosteer (github/mtz8302). This sends the commands via wifi UDP to a small Wemos D1 mini I have built in in the steering wheel. From this Wemos the commands are sent via a RS232MAX converter to the wheel. So the wheel is only plugged with a power cable. The data transfer also works in the other direction.
To mount the motor on the tractor I use a selfmade adapter and a cheap racing wheel.
Yes, I am sure that the smaller one also is strong enough for any kind of hydraulic steering. (I am not sure for mechanical steering, sry)
In the meantime (I bought it in summer) the software of new ones seems to be updated. Now it should work that the motor gives some feedback for example if you turn the wheel. (My motor has some problems with this feedback)
This is smaller, the shaft hole is 23 mm, I donât know if it would be enough
Look at the datasheet of the steering oribitrol:
OGNIBENE Lenkventile Serie STZOR (Reaction)
Orbitrol OGNIBENE série STZOR (Réaction)
âą Lenkradmoment: normal ca. 3 Nm
manuell 120 Nm
max. 240 Nm
âą Couple au volant: normal env. 3 Nm
manuel 120 Nm
max. 240 Nm
Very nice mounting !
Do you have a datasheet of this motor, especially about the RS232/CAN interface ?
Math
I plan to make a fork of the GitHub-Code wich I use (GitHub - mtz8302/AOG_Autosteer_ESP32: AgOpenGPS V5 + V4 autosteer code for ESP32 ) to implement my code. But I just started learning Github, so it may take a few weeks.
The new datasheet doesnât exactly correspond with my motor, so I am not sure if my code could work with this versionâŠ
Im am not allowed to upload a pdf, but yes I have one. ![]()
This one could work :
https://www.aliexpress.com/i/4000643632108.html?spm=2114.12057483.0.0.1d6c66744sr9XM
Arf yes you cannot upload pdf. I search on the Aliexpress page and manufacturer website but I didnât found the datasheet.
Iâm interested to see how the motor is commanded throught RS232.
Math
Seems to be this factory. Download pdf from their website.
Yes it is it! It is not the newest version but itâs ok for understanding.
It seems I am not allowed. I tried and I am only be allowed to upload jpg, jpeg, png, gif, txt, kml, xlsx, ino, cs. ![]()
But it didnât change very much, so tho older one is ok.
Here is the actual version:
I renamed the extension
KY170 Electric steering motor user manual V1.4 pdf.txt (987,9 KB)
This model with 85mm hollow can easy adapt to steerwheel, and thickness only 33mm.
Thank guys, I didnât search on the good website !
Math
has anyone tried to control the vesc via uart?
https://youtube.com/shorts/93bcVAeCDP0
https://youtube.com/shorts/lCea64AWyBU
First field test with my brushless ![]()
That is brilliant!! ![]()
i like it
Nice work Giovanni!
