To eliminate IMU influence set antenna height to 0 and make IMU GPS Fusion 100% GPS.
Lower your motor setting to barely come to line, then up aggressiveness till it starts to oscilates little then lower back down to best result. Then try 90% IMU 10% GPS fusion and compare results. (Look ahead should go down as you go toward more IMU). And after that try normal antenna height.
