Complete beginner here, i have been reading through the Wikis, the Combine forum and the AOG.
still confused, but hoping it will come clearer with time.
What i hope to do is start with a basic set up, where the “light bar” on the screen is used for guidance. then progress to auto steer and finaly put in an RTK base and have full RTK auto steer.
Is this a sensible approach ? is it in the correct order ?
I have a Toughbook but ill need to source the rest of the hardware.
You could do it that way, or get RTK before autosteer.
Reason being the lightbar and thus also autosteer will only be as precise as your GPS signal.
So if your GPS signal is off by x cm your lightbar and autosteer will be off x cm as well.
