If you could supply me with a PCB that would be a great help
Let me know how you want to sort payment
Are you about this weekend? Can drop it over to you if that helps.
Actually I have your number, will give you a call.
You only need one relay, you have choice do you want to solder relay to PCB (CB1-P-12V) or use relay socket with other relay.
Conn RCPT 6pos 0.1 gold PCB 20Pcs 10 Pairs 40 Pin 1X40 Enkele Rij Mannelijke En Vrouwelijke 2.54 Breekbare Pin Header Pcb Jst connector Strip Voor Arduino Black|connector strip|pin header connectorstrip connector - AliExpress
you can use them for entire PCB. Just break off exact length that you need.
https://eu.mouser.com/ has VX7805-1000 in stock
any linear converter to 5v (1A or more) that fits should work can someone confirm this?
https://www.digikey.com/en/products/detail/cui-inc/V7805-1000/1828608
BNO085 I use from aliexpress no problem.
If you will use the hammond alu box, you must solder this relay.
hi can you let us know what seller you use - have had multiple orders cancelled
But of course out of stock.
Hard to find in stock BNO08x or CMPS14 if you can wait backorder them from suppliers for normal price if you cant they are 2 or 3x price on ali probably in stock.
If you cant find IMU or is too expensive you can go dual antenna. If IMU prices fall you can split system to 2 tractors with single GPS and IMU.
Is it possible to put together an auto steer system by May with parts availability the way it is? If not I will just abandon it until this winter.
Everything I try to order seems to be out of stock or backordered and I am still somewhat confused what I need to build a system and what version I need, there is no valve on the tractor. I donβt know if there is a βgo toβ place to get this stuff ordered or not.
Thanks!
What country are you in?
My relay is with sockets and it fits in the alu box
