Thank you for being so helpful, I will order parts in few days. One more question, how much mobile data it uses? For building base station, what parts do I need/ You recommend?
Little mobile data but windows likes to update and use up alot of data so you have to select metered connection for that wifi.
I did rtk with 2 ardusmiple kits
One kit as rover/tractor
One kit as base station and you need some way of NTRIP server there are some options like
You can make wifi ntrip master from esp32 if you like
ESPRTK
Raspberry pi base
There are SNIP and u-center for windows
And many other ways…
I use u-center as server and caster
https://learn.sparkfun.com/tutorials/how-to-build-a-diy-gnss-reference-station/
I followed this tutorial you have other explanations on that site for this topic. With this you dont have to go with rtk2go you can connect directly to your ip you just have to portforward on ruter. If you dont have static ip its better to go rtk2go way.
many options you need to chose what hardwere you already got or want to buy I have 3 laptops laying around so it was easy choice for me.
Soo, I found 3 stations near me, all of them 20-30 km away (it is showing that they cover about 39 km). Is there any tutorial on how to use RTK2GO? Thank you for help, time and effort you put into learning me.
Do you mean how to get RTK corrections from a base listed at RTK2GO?
Instructions here, pretty straightforward:
http://rtk2go.com/
Wow, that must be the slowest delivery in history!
Pleased you have finally received it, thanks for letting me know.
Did I only send you three of the blue capacitors?
yes what you see is all !!!
I meant to include 4, sorry about that.
Anyway, at least you have the boards, have fun with them!
What is parts availability like as i’m looking to build a PCB and have down loaded the parts list on to Digikey but it just says ‘exact match not found’ for every item.
Am i doing something wrong or are the parts not available to build the boards at the moment
tell us witch parts is missing and we can propose a solution to substitute it
There are some shortages of parts but no all of them.
When you upload PartsList.xlsx:
“Please select the row where part info begins and verify that all columns are mapped appropriately.”
Try finding parts by google searching part numbers, there are a lot of shops keeping same parts or ask hire for substitute if you can’t find any.
for me you can replace by LM7805 1A or1.5A they do same dask
The difference VX is DC DC converter and the LM is positive linear regulator.
Pins layout are similar
if you are afraid you can add piece of aluminium to cover the heat
it is what i do you can check the video at 12s where i weld it on previous post
I use this since the begining and i haven’t issue
After putting the column headings in as Radmuffins posted, i have got the list up loaded to Digikey.
The 4 things that are out of stock are
DC DC converter 5v 5w
Relay automotive SPTD 40A 12v
Conn RCPT 6pos 0.1 gold PCB
Relay socket 5 pos through hole
Some of the parts above have a lead time of 28weeks with Digikey, where would be a good place to try and source the out of stock parts listed above
Also where would you source a BNO085 from as about the only place i can find them in stock is Aliexpress but i have read on here not to use them from there
Cheaper
What country are you in? I might have the parts you are short of.
I will try rs online as I need some other stuff off them
Uk, I am 30 miles from you
Ah yes, sorry I meant to get back to you, but got snowed under supporting someone else.
Have you ordered? Do you want a PCB? I have four on the bench.
