Benefits to was in differential vs singular mode
I was wondering if running a WAS such as the rty dual output version in differential mode has any affect on signal quality or resolution? the inverse slope variant if the rty runs dual opposite inverse slopes which a differential signal could be read from. I have not seen much talk about running a was in differential apart from installs with factory was installed. can anyone confirm if there is there any benefit to it? if so, it would be great to be promoted more as it would just be running 4 wires to the was instead of 3, of course the only thing is the was has to be capable of 2 opposite signals. This dual signal rty is also much cheaper then the signal signal rty variant https://au.mouser.com/datasheet/3/705/1/hon_ia_hss_rty_dual_output_data_sheet_en.pdf
