it will be in docs when they come out. used to be a form window of them but not sure where that went, need to find it again
Thanks for your time and your answer
I was running usb section control on my planter last year V4.3.1 i believe. Plan to use v5 AOG this year. Is the USB section my best option. I dont see an UDP section for arduino in the module folder?
For now yes, haven’t made a udp one.
The code is there. It’s a all in one code: section control, with/without switches or documentation only.
Versions for Arduino or Arduino nano33iot or ESP32
And it will work thru ethernet?
trying to flash to and esp 32 and got this messag.
Edit I opened all files in the folder and then it loaded Thanks
