We should collect some experience first.
When creating an AB line on the map, it always appears offset from the chosen location.
Another possible error (I donāt know if it is) is that when creating the boundary curve, it always appears separated from the boundary with a distance equivalent to half the width of the implement. In the example I am using a 1800 cm sprayer and the default value for creating the boundary curve is 900 cm. I would like to be able to change that value to a slightly larger one like 950 to have a safety distance between the spray bar and the boundary, but every time I select 950 or another value the line does not move and is always in the 900 cm place .
The touch ab really only works along the edge - the straight line going up on left side, if you want an abline to follow the edge. if you want some xxxx degrees line you have to make it the other way using A B or A degrees.
There arenāt an infinite number of points along the boundary and you can never touch the right on. So use an edge is best
I will check about the offset
Donāt know if itās a bug or not but, itās detail, but some text seems to be white instead of black: not very readable depending on the screen.
Math
Solved yet. Thx Math
New bug found. When trying to open a field, AgOpenGPS shut-off, whithout any error message.
Try on 2 very differents devices:
- My labtop
- My Shadow Computer (cloud based computer)
Same behavior.
See following video:
Math
The same problem heppened with me
me too
The 15th has already arrived. delay your computer date and try again.
Thatās really funny. Bug finding has now its end. ![]()
Yes, that version is toast. Real one coming soon, Jaap is just finishing up the inoās, Vili the graphics, and Daniel and I are making more bugs ![]()
Thank you to all who have helped find bugs and problems. Your work is vital to making a smooth running program. Many eyes see so many things - huge advantage of this great community.
Ahhhhhhhhhhhhā¦so close!!!
Ok!-) (Last paragraph is meaningfull, skip if in hurry!-)) (edit: somewhere in the end anyway, i just got carried away with everything ⦠sorry ^2 )
(that āOK!ā is for me for realizing, I HAVE to be logged in before replying works⦠so, I might not be the sharpest pencil in the drawer or how the saying goes. And yes, kick me out NOW, this is my first message, and I kind have habit to write (and talkā¦) too much about things that are not really relevant. Almost constantly. So the warning is on, moderator(s) take your acts, or axes?-) )
Maybe Create āintroductionsā āforumā (really not familiar with this platform, and english is not my native language) where people can tell who, why and where, if they wantā¦
Real question (not bug report, sorry!):
Hi everybody. Sorry to bother at times like this, but if i WANT to test something out NOW, what version should I get?
I just like to get little known to system, but if timeline is days, is it best just wait for this?
There is meter of snow at ground here in Finland, so really no hurry, but you know, you āinventā something new, you just want to go for itā¦
(Ouch⦠on right there is panel āDoes your reply improve the conversation?ā,⦠SORRY!!)
As far as I know this forum has no place for introductions, but the best place might be under the getting started category. As far as the best version to try, here is a link to the most stable release on Brianās GitHub.
Topic closed due to new beta release
