New version uploaded with a million less bugs. Thanks again for the help!!
how do we connect the devices
There is a little bug when we put the first u turn distance. The distance is not saved correctly.
ok thx
Maybe an icon is missing here!
When I want to change the language, agopengps must restart and when I click on exit I get the following error.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: Collection was modified; enumeration operation may not execute.
at System.Collections.ArrayList.ArrayListEnumeratorSimple.MoveNext()
at System.Windows.Forms.Application.ExitInternal()
at System.Windows.Forms.Application.Exit(CancelEventArgs e)
at System.Windows.Forms.Application.Exit()
at AgOpenGPS.FormGPS.menuLanguageFrench_Click(Object sender, EventArgs e) in C:\Users\FarmPC\Desktop\SourceCode46\GPS\Forms\Controls.Designer.cs:line 1069
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
AgOpenGPS
Assembly Version: 4.6.2.0
Win32 Version: 4.6.2
CodeBase: file:///C:/Users/benoit/Downloads/ProgramV4.6-B/ProgramV4/AgOpenGPS.exe
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Win32 Version: 4.8.4320.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
OpenTK.GLControl
Assembly Version: 1.2.0.0
Win32 Version: 1.2.2336.6514-pre
CodeBase: file:///C:/Users/benoit/Downloads/ProgramV4.6-B/ProgramV4/OpenTK.GLControl.DLL
OpenTK
CodeBase: file:///C:/Users/benoit/Downloads/ProgramV4.6-B/ProgramV4/OpenTK.DLL
Control.Draggable
Assembly Version: 1.0.7235.37687
Win32 Version: 1.0.7235.37687
CodeBase: file:///C:/Users/benoit/Downloads/ProgramV4.6-B/ProgramV4/Control.Draggable.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
RepeatButtonControl
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/benoit/Downloads/ProgramV4.6-B/ProgramV4/RepeatButtonControl.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
When I want to change the value of a field in the vehicles or tools section I get the following error.
System.IO.FileNotFoundException: Could not load file or assembly âKeypad, Version=4.3.10.0, Culture=neutral, PublicKeyToken=nullâ or one of its dependencies. Le fichier spĂ©cifiĂ© est introuvable.
File name: âKeypad, Version=4.3.10.0, Culture=neutral, PublicKeyToken=nullâ
at AgOpenGPS.FormNumeric.InitializeComponent()
at AgOpenGPS.FormNumericâŠctor(Double _min, Double _max, Double currentValue) in C:\Users\FarmPC\Desktop\SourceCode46\GPS\Forms\Inputs\FormNumeric.cs:line 21
at AgOpenGPS.FormGPS.KeypadToNUD(NumericUpDown sender) in C:\Users\FarmPC\Desktop\SourceCode46\GPS\Forms\FormGPS.cs:line 941
at AgOpenGPS.FormConfig.nudVehicleTrack_Click(Object sender, EventArgs e) in C:\Users\FarmPC\Desktop\SourceCode46\GPS\Forms\Settings\ConfigVehicle.Designer.cs:line 330
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.UpDownBase.UpDownEdit.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.TextBoxBase.WndProc(Message& m)
at System.Windows.Forms.TextBox.WndProc(Message& m)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
mscorlib
AgOpenGPS
System
System.Drawing
System.Core
System.Xml
OpenTK.GLControl
OpenTK
Control.Draggable
Accessibility
RepeatButtonControl
enabled.
For example:
Other bug.
Version 4.3 or 4.61. Every version.
I have a 36 meters sprayer.
I click on Headland when i am on my field.
I have this error each time.
I have to change my tool to 4 meters. Then i click on headland. Make headland with 36 meters. After, i return my tool 4meters to 36 meters and it is worked.
Fields make 15 hectares here
The field is too small to display all the text in French (Supprimer la zone apâŠ)
I notice that not everything has been translated into French in the new version. I can take care of it if someone tells me how to do it.
We have not done anything in the translations yet, it is using vs 4.3.10
ya a visual studio update changed how Application.Exit() works. been that way since v 3 and all of sudden it doesnât work. Crazy.
@charlesdego i increased the max to 150 for 50m tool times 3. solved the problem, but now i have to ask, what is the best way to make a headland default? maybe a âheadlandsâ pulldown to select how many tool widths you want the headland to be. because i am sure you donât want 3 sprayer widths!!!
Thoughts?
oh yes, i want only 1 pass for my sprayer. ![]()
Good idea for asking how many tool widths we want.
Idea : when clicking, default can be 1 and after we select how many we wants.
I can create just one boundary curve with the touch line editor and I canât change the name of the boundary curve in the editor. But I may need one boundary curve for seeding, one for spraying, ⊠. (There is a work around. I can change the name in the abcurve form and then I can create a new boundary curve with the touch line editor. But this is a little bit laborious.)
aog needs a restart to take effect of the setting of this button.
it wasnât saving it as it should when exiting config. Who would have thought it could have so many bugs!!!
You will like the new form!!! I hope ![]()
Now it doesnât assume, you tell it how many headland passes you want, then add a bit more with the spinner.
That was all done to prevent people from clicking outer boundary 87 times. Its a big guidance line all the way around a field, you only want one per field - or two like you are doing,
too much hassle? Maybe i can think of a better way to prevent clicking till it crashes.
It is great! ![]()
Thanks you very much!
Its funny ya know, you see the updated form and go, âWell why not do that in the first placeâ âŠ
I guess that is why cars started out like this:
