I examined the UDP machine version. relays are opening and closing. But it needs me to open and close for a second. how do i do this? can you help me?
I found this software but you’re done. It needs to be a standalone code like the ardunio nano udp_machine code. Can you help?
So the relay needs to open for a second? Is this for hydraulic lift, or section control?
Relay; It will open, then close after a second. It’s like pressing the button and exiting.
did you try 255 to get continous function
