Canbus on Case IH
Cnh 1 worked. Thanks
What code should I enter to make the button on the armrest work?
Commonrail board, 2024 NH T6 tractor
The commonrail code was entered via Configomatic, connected to the green connector behind the seat with CAN3, and the button on the armrest doesn’t work.
I should add that when I connect the second set of standard AIO boards, everything works as it should.
tried these?
You need to go into serial monitor and select the nh brand
Everything should be on can 3 on the pcb and connect to either the green diagnostic plug or the pins at the 40 pin connector
you’ll need a 2nd CAN circuit going to the upper diagnostic port (that has ISOBUS + armrest)
