The old Auscors url auscors.ga.gov.au is no longer available. Have you changed to ntrip.data.gnss.ga.gov.au?
Sometimes I get a patchy connection, and I’m not sure if it’s the phone, tablet or caster. Restarting everything usually resolves it, or mashing the confirm IP and bringing up the mount table gives it the right motivation.
Thankyou I changed it and it worked. It does seem to be a bit slow as I turn on the headland tractor icon is a bit behind in turning. Also the speedometer shows I’m doing 32km/h when I’m actually doing about 4km/h not sure what the issue is .
Run it, and type “agio” in the box at the top as a filter. The line you’re interested in is the “Remote Port” with a value of 2101 (unless Auscors is different?)
If your connection is having issues, then you’ll keep seeing the bar go red and green as it tries to contact, or re-establishes contact with the NTRIP server. If it stays on Established and the Local Port number doesn’t keep increasing, then you have a stable connection (which in your case then, might imply the auscors service is perhaps having issues). In my case, I’m connecting to rtk2go here, but the reverse IP of that is Amazon hence the weird hostname.
I had this issue using rtk with version 5.6.2 . I think there is a known issue with the AOG 5.6.2 release and speed calculation. I am using PANDA but i don’t think it is related to that. I’ve upgraded to 5.6.15 and reenabled VTG message from the F9P
Hi again I upgraded to V5.6.14 uploaded firmware to and configured the f9p
and now I have lost RTK not sure what is wrong but I can still access satellites on Agio as per the photo and I can also get an IP address when I Confirm IP .
It usually gets 5 or 6 but I have had up to 10. It says invalid where before when it was working it said rtk fix and showed lat long and showed messages in the GGA and VTG boxes
