You can use two types of switch. One that stay on, or only on when pressed. Try both for your type, as it might be opposite of what you think.
When not moving, you must use the red tractor button in the expanded steer setup window, to make AOG to output pwm.
Note: I have seen once that the NONE option still needed at least one click on physical steer switch.
