Controlling rear hitch, electric remote valves and shuttle (fwd/rev) on a New Holland T7 — any existing projects?
Hello everyone,
I’m working on an experimental project on a New Holland T7 and I would like to control three functions electrically, triggered by GPS position:
the rear hitch (raise / lower)
the electric remote valves (hydraulic spools)
the power shuttle (forward / neutral / reverse)
My current plan is to tap into the existing armrest buttons/paddles and the shuttle lever with opto-isolated relays (driven by a Raspberry Pi), mimicking the operator’s inputs — similar to what was done in the John Deere HMS thread. I know the CNH fault codes (ARM/TMF) monitor switch plausibility, so I plan to measure all voltages first and use dry contacts only.
Before I start, I would like to know:
Has anyone already done this (fully or partially) on a NH / Case IH (T6, T7, Puma, Maxxum)? Hitch and valves, but especially the shuttle — I haven’t found any thread about controlling forward/neutral/reverse.
Does anyone have the armrest wiring diagrams or measured voltages for the hitch buttons / EHR paddles on a SideWinder II?
Has anyone identified the CNH CAN messages for hitch or shuttle control? I saw the Case Puma 175 CAN-bus thread about steering — has the rear hitch part progressed?
I have a CAN adapter and I’m planning to record the bus while operating each control. Happy to share my recordings and measurements from the T7 to contribute back.
Thanks a lot!
