Danfoss valve, pressure sensor location
Hey so I’m installing a danfoss valve on a Case STX440, where would be the best location to add the pressure sensor to detect manual intervention? And also what type of output signal does the sensor have to have?
The sensor should be on the orbitrol LS line.
For the AiO board it must either output a 0-5v or 4-20ma signal. You select it with a jumper on the board.
