If you want the source code you have 2 ways. Go to the main github page https://github.com/farmerbriantee/AgOpenGPS Click on clone or download and select download zip. Unzip the file and run AgOpenGPS.sln to open in Visual Studio.
You can also click on the source code on the release page to download the source code associated with that particular release.
I don’t know if I am missing something here but I’ve tried to download and install this in three seperate PC’s and the application will not open. I got it to open on one PC by running in safe mode but resolution was poor. The wiki document mentions deleting the user directory if ot won’t open but that seems to do nothing? Anyone have so tips on getting this working?
I made a quick video for showing how to download v4 my apologies there is no audio on this one. An issue maybe that windows blocks the program unless you click more info and then run anyway. Hopefully this video shows what to do. The AgOpenGPS folder that is mentioned to delete is usually in Documents.
I tried following your video with the same result. The warning from windows does not come up. I am using windows 7 and thought AOG was compatible? I tried turning off windows defender, deleting anti virus, and nothing works. the task manager shows the application running but nothing on the screen?
I would like to add that it opens with the computer in safe mode so there is something in the windows program that wont let it open I am just struggling to figure it out. I am surprised no one else has had this issue?
No problem with v4 on win 10 pro, on a Lenovo Thinkpad T420 with core I5
Must admit that laptop had never had any previous AOG versions , if that could be an issue.
Good news, Not sure what I did but it worked, I opened a new user on the PC and put the downloaded file in the new directory extracted it and it opened? Thanks everyone for your help.
I had similar issue with windows 7, when starting the program nothing appears on screen. But in task manager you see that AOB is running.
When using safemode the AOB started OK.
Eventually the issue was caused by the setting “text size” which I had in 125%. after switching to 100% AOB started properly.
