It should, and others have worked on it Dual GPS using SkyTraQ receivers.
I have a working system based on this, however have issues with losing RTK. This appears to be an issue with suspected temperature compensation as you can blow on the receiver and it will lose fix. I also have a system with a F9P and it is rock solid. No troubles with it at all.
Another minor thing is it takes the corrections on one usb and outputs the position on another so I haven’t been able to use the NTRIP through AOG as you can with an Ardusimple board for example.
<Edit: this seems to have been updated so can use just one usb. I will need to update my firmware and try this…>
