Just bought a JD 8400 with an autosteer valve used with a trimble system. Im including a picture is their any reason why this couldnt be used with AOG. using PCB V2 with the cytron MD13S
Il gâche l’achat. Puisse-t-il servir longtemps sans urgence.
Should work. The yellow block must do the separation (check valves or something like that) so oil does not flow from A to B when not in use. Try 12 volt to one spool and then see. (even 12 v will give a little oil to steer)
