Ethernet Setup Help
Thanks @wland! The group policy change worked, but I did have to restart the computer and reconnect the Ethernet before I saw the change.
Thanks,
Jon
I had some additional issues with my toughbook CF-H2. Here is the solution I found through some help.
"I found in the tray there was a utility running called “Wireless Switch Utility”. I had a hunch that it was responsible to turn off the WiFi. So I used Task Manager to “end task” that Wireless Switch Utility, and I disabled it from being a Startup app (so you don’t have to worry about it when restarting the computer).
That worked. Immediately both the Ethernet and the Wifi would both stay connected."
Thanks for everyone’s help!
