Has anyone tried hooking up an old itc receiver as they are relatively cheap and soon to be cheaper as they are going to be cut off from sf1 correction
Sure it would work, giving you WAAS accuracy levels. That’s enough to steer by provided you don’t mind the lower accuracy, which means your overlap is going to vary by a couple of feet. The benefit of the Starfire receiver is that it does roll compensation internally, so the output should be fairly well filtered.
But keep in mind a lot of low-cost GPS receivers based on ublox chips can do WAAS if that’s all you want. And a ZED-F9P (or pair of them) isn’t that expensive and is capable of RTK. To me the benefit of RTK is repeatability. I can save a line and hit that same line year after year.
