My F9P is magic, it will report all that are not behind the mask.
Just change the max allowed and see all of them.
thats look nice i try to find the settng but don’t find it
start with f9 or ctrl f9 ? wher can i find the advanced mode
can you make a copy of your setup file ? normale it should work her even good when i load them
Click the “view” menu, “Generation 9 Configuration View”, then “advanced configuration”, “cfg-NMEA” and you should be right there.
I am running spark fun SMA F9P’s, so I am not 100% sure its fully compatible with the standard AOG Ardusimples board and connections. So my config so far is custom.
I’m looking forward to changing that setting, I’ve always been disappointed that AoG didn’t show the full number of sats.
F9P will only report the ones that are usable above the degree mask in the GGA, so you may still see 35 siv in u center and 24 from the GGA.
So many tweaks lol
i found the setting strange the setting was set on unlimited i could change to 8 12 or 16
set it now to 16 in aog i stil see 12 in u-center 32
I’m wondering if somebody can help me out, what is the problem if AOG shows every little while “No GPS” when i have the RTK board connected?
First make sure you are only sending gga and vtg.
Second look if your windows computer has usb selective suspend activated, turn it off.
Then try another usb cable.
Alright, thanks.
Right now trying to figure out U Center to configure the board… to change the msg to the (only) needed ones.
What type of F9P board are you using?
There are preconfigured files to help get you up and going.
I have the simplertk2b LR kit. Somehow i can’t get the configuration file on it. I think because of firmware needs updated.
Hallo Fons , ik gebruik ook Flepos, van welke regio in Vlaanderen ben je ?
