Hall effect encoder disengagement
I’m certain I have seen others using a hall effect sensor and magnets mounted on the steering shaft to disengage steering on their hydraulic systems but I can’t for the life of me find any of those threads now. Does the sensor just need wired into the remote switch and then it cuts the steering off after 2 or 3 pulses?
Thank you!
Yes. See the schematics (turn sensor) here Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
In the settings page you activate Turn Sensor and you also put in number of impulses.
Is your hall sensor 12 v or 5 v ?
If it is 12 V you should be able to connect it to the 15V pin beside the O and GND
Here is a link to more about reed sensors: Reed Switches and Hall Effect Sensors | K&J Magnetics Blog
Thanks guys!!
