Help Configuring Radio RTK
I have purchased an ardusimple base and rover kit with LR radio for RTK corrections. The base and rover have been preconfigured by ardusimple.
To connect the GPS on agopegps I just opened AgIO and selected COM3 and I have GPS connection but no RTK.
Can someone please send me a link to a set up guide or some screenshots about how to configure radio RTK please?
John
Both receivers have their antenna under open sky? The base has had enough time to obtain base location (not sure how ardusimple have configured the survey time)?
I don’t think I had to configure anything in mine either. Make sure you are using correct rtk2b and radio for rover. Should be labeled. Other than that, set up far away from trees or buildings. U center is the software you need on laptop to configure. When you connect to rover, it will tell you more info. Makes troubleshooting much easier. Shouldn’t have gps if wrong baud rate, but I would double check that on u center as well.
As the guys say, there is no configuration necessary. Have you flashed your base and rover with the base / river configs?
