Are you building variable rate control or just want section control?
What are those red knobs on the valves? When the section is off is there flow through them?
If there is flow through the red knob with section off, set this to the same flow as the section. Then connect your AgOpen section relays between bravo and valve as below. The standard Bravo switch will be the master and must be ON, then AgOpen can turn it off, if the red knob is bypass and set same flow the Bravo will just think the section is ON but might be ok for your needs?
CommonRail I want to disconnect sections from AgO automatically if there is an overlap. If I turn on the DPDT relay instead of the switches, so that they turn on from the AgO, then I will have all the BRAVO functions that are there. The relays will act as switches. AgO will turn the sections on or off. The switches reverse polarity + \ - - / +. I’ve already figured it out. It will be the same if you turn on / off the section manually.
Yes, I think it will be possible to try to connect the AgO relay in series to the open circuit of the solenoid valves. There is a bypass for the drain. The pressure and flow rate will remain the same. Only the section will be disabled. This should work, thanks for the tip. I’ll try to try it tomorrow. The new sprayer has not yet been used. I will pour water and try.
I am trying to launch ARDUINO with BLUETOOTH. As if only one-way communication. I run it on the table. Nothing except BLUETOOTH is connected. Maybe you need to enable it on ARDUINO to make it work.
Additionally:
Bravo 300S interface to AGOPENGPS
The interface is my own project - it is the ESP32 which mediates between the Bravo computer and the switches. The system can operate autonomously or in the mode with AGOPEN. I removed the original board with switches, did a reverse engineering and designed my own PCB - matching plug and play in place of the original PCB:
Oryg PCB:
I use transistors to emulate physical switch by esp32 and read physical switches state. In manual mode it works normally but in auto AOG is sensing data to esp and set outputs !
It worked with bluetooth. Incorrectly set the bitrate 38400. By switching, I have already decided. As I progress, I will upload photos, videos. There was one unresolved issue. How to program. So that tact buttons are used instead of switches. ARDUINO MTZ8302 Firmware
