Thank you, i just need to get ahold of @baraki so i can get them ordered and paid for!
125 works very well.
The minimum PWM is 38 -40
The maximum depends on the size of the piston 100-180
P - depends on the size of the piston:
15 for small tractors
40 for the big ones
Thank you! Iāll try with these as soon as I get the AOG installation finished.
I have this valve connected to a steer pcb(kaupoi4.1) on my desktop with short wires. The laboratory power supply is set to 13 volts. The activation solenoids have a resistance of 7ohm/piece. On activation the autosteer coils will remain energized for only about a minute until the BTS442e2 gets hot, the voltage on the coils drops and the coils releases. Is this too much load on the mosfet and should a relay be used here? My understanding is no. I tried changing the already bts442e2 to another one and had no effect. With one coil only connected temperatures remain reasonable. Bts442e2 is equipped with heatsink.
The BTS442 is not good enough for large current, itās only good to drive a relay
I looked at the datasheet for BTS442E2 and the maximum on resistance should be 18mOhm (15mOhm typical). If we calculate power loss from that itās ~4A * 18mOhm = 0,072V voltage drop over the switch and that gives 0,072V * ~4A = 0,29W. According to the datasheet The thermal resistance from case to ambient air is 75 degrees celcius/watt and from chip to case 0,75. That would be 0,29W * 75,75C/W = 22C. So if the ambient temperature is 25C the chip should get around 47C and thatās without a heatsink. Iām not saying it didnāt get hot, Iām just saying it seems strange to me.
I have a switch ic with 60mOhm on my board for that same pair of valves, that should be almost 1W and I have an SMD component with a small copper plane for cooling and I didnāt notice that it would get hot just a little warm.
Could it be something else thatās wrong? Like if its turning on and off rapidly all the time, swiching losses are a lot higher than when it is fully turned on.
Iām going to test mine tomorrow again to make sure it doesnāt get too warm.
Many of my installations run on Kaupoi Bts boards without a heatsink with these two valves and never had a problem. I just connected one disc to check if Bts heats up, when I touch it with my finger it is a bit warmer but I wouldnāt say hot.
Coils are hot too. Is 7 ohm resistace normal? I test tomorrow with battery as powersupply (without lab power) in case itās causing something that you canāt see with multimeter. I cant figure out anything else because there is no much in pcb before bts, which is already changed.
I power it from a small 12v battery. The coils get quite hot, but thatās normal. Perhaps the power supply is the problem, I recently had a similar problem with my automatic bandsaw. I built a new Mega 2560 control for it, the 230V coils caused problems with interference, so I replaced it with a 24V powered from a 230/24 power supply, the coils started smoking after a few minutes. Replacing the power supply solved the problem.
Tested with 12V battery. Same result, bts get very hot and cut off. Measured also voltages at BTS pin 2 and pin 3 +vbb. They are ok. Maybe next test just plain bts without pcb.
Bts I use
is this: 5Pcs 10Pcs 20Pcs BTS442E2 BTS442E BTS442 Om 220 Beste Kwaliteit|lot|lot lotlot 10pcs - AliExpress
Is the BST back gnd or 12v? Is the head sink the problem? Making a short?
Same without headsink?
Bts frame/tab is connected to +Vbb pin3. Heatsink leg on pcb is not connected anywhere. I tried to remove heatsink anyway but but nevertheless the BTS is warming up too much.
After this test I took plain BTS without any pcb connected output to coils, 12v battery to vbb and 5V source to input pin. Same behaviour this way too. Then replaced coils with working light to see if there is something with coils. Still the same result.
Now I Think there must be something wrong with those particular BTS mosfets.
Where did you buy these Bts442? Maybe should try same source if could find working pieces.
Thing is with the BTS442E2 they dont manufacture them anymore. Anything you buy of them is either old stock or copies. Maybe you happend to get a bad batch of copies. I looked a little bit at mouser and at Infineon if I could find a replacement with the same pin mapping but no. It seems that the ones in to-220 package is rare.
Despite BTS difficulties, OC Valve installed on an old-school Valmet 05-series tractor in place of the glass washer fluid tank.
P & T -hoses 1/2" like original, others 3/8"
Today I also helped to install in NH T7
Is there a schematic how to install electrics to new all in one PCB? With deutcsh connector.
Do I need a Resistor in the wire to the pressure Sensor?
